Buzzsaw General
Member
DerekGCWhite
Message 1 of 8 (11,723 Views)
DWG TrueView 2012 - Measure area gives strange results
11723 Views, 7 Replies
09-14-2011 05:18 AM
When I use TrueView against DWG files I get exact figure for the Line measurements however; when I attempt to measure an area I obtain answers that are way away from what would be expected
Has onebody any ideas as to how I can get this to work?
Does anyone know where I can download a version of 2011 or 2010 so I can check whether it is the 2012 version or my system?
jforish
Message 2 of 8 (11,508 Views)
Re: DWG TrueView 2012 - Measure area gives strange results
10-20-2011 10:29 AM in reply to: DerekGCWhite
Hi
I have an installation doing the exact same thing. Any help or suggestions would be great.
jforish
Message 3 of 8 (11,505 Views)
10-20-2011 10:43 AM in reply to: DerekGCWhite
I just stumbled onto the answer. It seems that you have to do your area measurements in Model space. When measuring in any of the layout tabs I get crazy results, in model space it measures exactly as in Autocad.
Member
DerekGCWhite
Message 4 of 8 (11,497 Views)
10-20-2011 01:25 PM in reply to: DerekGCWhite
Many thanks foryour reply and I am glad you managed to find a way around your problem unfortunately with me when I go to the model tab of the drawings I am using all I am presented with is a black background
You may deduce I am not an expert on this drawing tool and you would be correct although I am surprised that such simple function would be so difficult
jforish
Message 5 of 8 (11,492 Views)
10-20-2011 01:36 PM in reply to: DerekGCWhite
That may or may not be bad. I'm not real familiar with the program, but in model space I would assume you can zoom to extents. If nothing shows up at all, then the original drawing must be done in paperspace. (Not standard practice). Taking a wild guess here but you should be able to get the scale factor for the drawing, (it should be on the titleblock), take an area measurement and do the math. I may be way out in left field, but I think it would be worth a try.
Good luck
Member
DerekGCWhite
Message 6 of 8 (11,489 Views)
10-20-2011 03:08 PM in reply to: jforish
jforish,
Many thanks and yes that is what I do. I use the line measurements and then resort to the calculator. I am an Energy Assessor and require detailed areas for the calculation so having to do it manually is a pain that's all and far more accurate than scaling off a paper drawing
kathy
Message 7 of 8 (11,299 Views)
11-30-2011 01:59 PM in reply to: DerekGCWhite
In Autocad - it usually has to do with how your units are set up in the drawing. If you hold the mouse over the area information in the propertys dialog box - it may tell you a different measurement - ie- I usually get sq. inches when I get drawings from architects - but if I hold my mouse over the area info - it will show me sq ft.
Dont know if this is what you're talking about - but hopefully it helps.
The drawing should be drawn to 100 percent - full size in model space.
New Member
jnpc
Message 8 of 8 (7,086 Views)
04-02-2013 08:02 AM in reply to: DerekGCWhite
Maybe you know this already but here it is.
-> Measure.
-> Select your 2 points.
-> Press F2 and the exact distance ( hypotenuese) will show in the Text Box.
Textbox can also be selected in tools, press cancel if prompt pop up box is in your way.
You are not logged in.
New Buzzsaw Category!
The Buzzsaw forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
Ask the Community
