Buzzsaw Forum Archive
Welcome to Autodesk’s Buzzsaw Forums. Share your knowledge, ask questions, and explore popular Buzzsaw topics.
Buzzsaw Synch does not synch when I am not logged on
2 REPLIES 2
Driel1973
1203 Views, 2 Replies
Hello!
We are using Buzzsaw Synch on a server to which files are posted that need to be synched with Buzzsaw.
Buzzsaw Synch has been set to synchronize continiously, however it only synchs when I actually log onto the server (I can also see from the Synch log, that it states 'service started' on the moment I log onto the server, so it does not seem to run when I am logged off from the server).
Is there any additional settings needed to have it run continiously without to need to actually log onto the server?
Thanks!
Erik
Tags (1)
2 REPLIES 2
bholle
in reply to: Driel1973
I have been looking into this issue myself, we are experiencing the same issue.  Right now i have an idea to use a vacant computer to sync all projects and just leave this pc on all the time.  Sorry i have no real answer for you.
eric.shipwash
@Driel1973 wrote:
Hello!
Thanks!
Erik
The Buzzsaw sync service needs to be running in order for files to sync. The sync service will only run when you are logged into the machine/server that sync is installed to.  At this time it is not possible to sync when not logged in to the machine/server.
