Buzzsaw General
Distinguished Contributor
ChuckEdwards
Message 1 of 7 (4,060 Views)
Buzzsaw Login problem
4060 Views, 6 Replies
05-07-2010 06:21 AM
trying to login into a buzzsaw account, using correct name and password and correct on the account details, I get an error:
"Could not send a server request. network error: error code: 12057."
Any suggestions from Autodesk as to what this might be?
It occurs on 2 of the computers in the office but not on another 2, however they are all setup the same way and testing with things like admin rights doesn't see to make any difference.
Active Contributor
jmcadres
Message 2 of 7 (4,059 Views)
Re: Buzzsaw Login problem
05-07-2010 10:39 AM in reply to: ChuckEdwards
Try this:
Go to Internet Explorer>Tools>Internet Options>Advanced tab>Security options group and uncheck the box next to option, "Check for server certificate revocation">Restart IE
John
andrew.grigg
Message 3 of 7 (2,219 Views)
07-23-2012 03:29 AM in reply to: ChuckEdwards
Just of curiosity, did this resolve the issue then? I can log on fine with this option 'checked'.
I have people asking about this a lot, and usually advise it's an IT issue at their end, sometimes re-installing the latest application does resolve the issue. But it'd be nice to offer more advice.
Employee
gregg.stanley
Message 4 of 7 (2,210 Views)
07-23-2012 06:43 AM in reply to: andrew.grigg
Product support has posted this as the solution:
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=15246533&linkID=9241337
Thank you,
Gregg Stanley
Gregg Stanley
QA Analyst
AEC
andrew.grigg
Message 5 of 7 (2,202 Views)
07-24-2012 01:54 AM in reply to: gregg.stanley
Hi Greg, thankyou for your prompt and precise response. I advised our user to try this, but unfortunately it didn't fix the problem. They are using I.E.9 though, which I suspect may have something to do with it, but I have asked them to contact Autodesk Tech Support directly to resolve the issue.
Employee
eric.shipwash
Message 6 of 7 (1,737 Views)
11-01-2012 01:56 PM in reply to: andrew.grigg
The error is typically caused by an out of date security certificate, which is unable to update on their machine.  If the users PC clock set to the wrong date and/or year can also cause certificate issues, I would check the users time and date settings as well.
andrew.grigg
Message 7 of 7 (1,729 Views)
11-02-2012 01:48 AM in reply to: eric.shipwash
Thanks Eric for the tip.
You are not logged in.
New Buzzsaw Category!
The Buzzsaw forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
Ask the Community
