Is there a way to convert a surpac file to acad file without ruining the drawing file? Our department is using ACAD in designing, while the Geology department is using this software called Surpac by Gemcom. My problem is everytime I ask for a copy in .dwg my file will only show the contours, all the texts, e.g. elevations and labels are not imported to the .dwg file which makes it useless since I need those data in my design. I attached a sample of the converted file. I hope you can help me with this.
Hi all!
that's my first time around here. I know that the above post is quite old but I have the same question.
If anybody can help, is there any way to export from surpac to autocad (dwg or dxf) keeping the description fields as well? right now, I just get the drawing but without anything.
Any help is much appreciated.
Thanks!
