Buzzsaw Forum Archive
Welcome to Autodesk’s Buzzsaw Forums. Share your knowledge, ask questions, and explore popular Buzzsaw topics.
Maintaining sync with a second computer
3 REPLIES 3
YeongWoo
1251 Views, 3 Replies
I'm about to replace this computer and I need to know if I will have to "resync" all my folders?  Is the sync process tied to this computer or to the Buzzsaw login?
3 REPLIES 3
eric.shipwash
in reply to: YeongWoo
Yes, you will need to reinstall the Buzzsaw Sync software and sync your projects to the new machine.
Eric,
I'm in the same boat...the sync'ed folders in question are on a company server.  From my new computer, they still show the Buzzsaw sync icon, but my Sync log doesn't show them, and I'm assuming that no machine is telling those folders to sync daily (my previous machine did this).  Will I need to delete the the sync'ed folders and replace them with new ones, or is there a way to re-link my buzzsaw to control the existing folders?
Hope my question makes sense....
nbraun
in reply to: WillMitchell
Hi – if the location of the local Sync folders were moved then the association to Sync was most likely broken. You can easily check this by right-clicking on the local Sync folder and see which options are available. If you see an option to “Add Buzzsaw Sync folder” then the association was broken and it’s not and active folder. If it is an active Sync folder you should have an option to “Update sign-in” or “remove synchronization”.
If the association to the file was broken then you will need to create new Sync folders.
Nick
