Buzzsaw Forum Archive
Welcome to Autodesk’s Buzzsaw Forums. Share your knowledge, ask questions, and explore popular Buzzsaw topics.
Buzzsaw on Mac, Parallels + IE - no connection :-(
2 REPLIES 2
298 Views, 2 Replies
Hi there!
We are trying to use a Mac with Parallels Desktop and Win XP installed to connect to the Buzzsaw server. We can establish a connection to the server, but unfortunately it won't accept the username and password, although everything works fine when using a PC only.
Any suggestions?
Eric.p
2 REPLIES 2
tconnard
Ack! The reason it's not working is likely because I gave the wrong subdomain. When connecting using WebDAV you need to use the webfolders subdomain:
https://webfolders.buzzsaw.com/sitename
If that doesn't work it may be due to the 'Parallels' app or Mac OS which technically isn't supported.
Let us know if the above works for you.
-Tom
jmcadres
It'll work. You're trying to login to Buzzsaw from the Windows virtual machine, correct? Whether you use Parallels or VMware Fusion (the two most popular Windows VMs for MAC), you'll get in. Confirm that you are entering the correct username and PW (case-sensitive). I use Buzzsaw on my MAC on a daily basis..........my virtual machine is VMware Fusion.
Good luck.
John
