Buzzsaw Forum Archive
Welcome to Autodesk’s Buzzsaw Forums. Share your knowledge, ask questions, and explore popular Buzzsaw topics.
Login problem
6 REPLIES 6
Timothy
507 Views, 6 Replies
Login problem
I am using the following code in Excel VBA to try to get the file name, create date and modify date for a folder on our site. I keep getting the error: "There was an unknown error." Any assistance would be greatly appreciated.
Sub ScanPPRevisions()
'* Delcare Variables
Dim oPPSession As New ppSession
Dim oPPFolder As PPFOLDER
Dim oPPFolders As PPResourceCollection
Dim oPPFolderItem As IPPResource
Dim sResourceUrl As String
Dim sResourceUrl2 As String
Dim sUserName As String
Dim sPassword As String
'* Set Variables
sResourceUrl = "https://webdav.buzzsaw.com/SiteName"
sResourceUrl2 = "Root/Folder"
sUserName = "xxxxx"
sPassword = "xxxxx"
On Error GoTo except
oPPSession.LogOut
oPPSession.LogIn sUserName, sPassword, sResourceUrl
Set oPPFolder = oPPSession.GetResource(sResourceUrl2)
Set oPPFolders = oPPFolder.SubFolders
'* Insert Column Headers
r = 1
Cells(r, 1) = "FileName"
Cells(r, 2) = "CreateDate"
Cells(r, 3) = "ModifiedDate"
Range("A1:C1").Font.Bold = True
r = r + 1
'* Loop through all items and list the file name, create date and modified date
For Each oPPFolderItem In oPPFolders
If oPPFolderItem.Type = PPFOLDER Then
Cells(r, 1) = oPPFolderItem.Name
Else:
Cells(r, 2) = oPPFolderItem.CreationDate
Cells(r, 3) = oPPFolderItem.LastModifiedDate
End If
Next oPPFolderItem
MsgBox "List Complete"
Exit Sub
except:
Dim sDec As String
sDec = oPPSession.GetPPErrorInfo(Err.Number)
MsgBox sDec, , "Login Failure"
oPPSession.LogOut
End Sub
Thank you
Tim
6 REPLIES 6
in reply to: Timothy
Is it supposed to be webfolders.buzzsaw.com? "Timothy" wrote in message news:16391539.1091488281548.JavaMail.jive@jiveforum2.autodesk.com... > '************************************************************************* > '* Set Variables > '************************************************************************* > > sResourceUrl = "https://webdav.buzzsaw.com/SiteName" > sResourceUrl2 = "Root/Folder" > sUserName = "xxxxx" > sPassword = "xxxxx" > On Error GoTo except > oPPSession.LogOut > oPPSession.LogIn sUserName, sPassword, sResourceUrl > Set oPPFolder = oPPSession.GetResource(sResourceUrl2) > Set oPPFolders = oPPFolder.SubFolders
Timothy
I have tried all of the following:
https://webfolders.buzzsaw.com/Site
http://webfolders.buzzsaw.com/Site
http://webdav.buzzsaw.com/Site
https://folders.buzzsaw.com/Site
http://folders.buzzsaw.com/Site
All return an error.
Tim
1. The two "normal" ways to access a site are: http://folders.buzzsaw.com/client/site http://projectpoint.buzsaw.com/client/site Yes you can use https instead of http. When http is used instead of https, it automatically redirects for user name/password transmission. 2. If you wish to access the site without using the ProjectPoint client, you remove "client" from the URL: http://folders.buzzsaw.com/site http://projectpoint.buzsaw.com/site 3. When I wish to access my site using WebDAV, I use "file open" in Internet Explorer, and I make sure to check the box for "open as web folder" and I use the URL: https://webfolders.buzzsaw.com The WebDAV protocol always uses https - even for file transfers. If you use http instead of https, I think it will redirect. I don't think webdav.buzzsaw.com is a valid URL. What happens when you try to open your site from the browser instead of the application. If you can get it to work from the browser, then we can look at what's going on in your application. Maybe its that "open as web folder" part that must be set somewhere in your code? "Timothy" wrote in message news:2533430.1091501125638.JavaMail.jive@jiveforum1.autodesk.com... > I have tried all of the following: > https://webfolders.buzzsaw.com/Site > http://webfolders.buzzsaw.com/Site > https://webdav.buzzsaw.com/Site > http://webdav.buzzsaw.com/Site > https://folders.buzzsaw.com/Site > http://folders.buzzsaw.com/Site > > All return an error. > > Tim
Do you know that the error is caused by the login code? Could the error be somewhere else in the code? "Scott Sheppard" wrote in message news:410f8786$1_2@newsprd01... > 1. The two "normal" ways to access a site are: > http://folders.buzzsaw.com/client/site > http://projectpoint.buzsaw.com/client/site > Yes you can use https instead of http. When http is used instead of https, > it automatically redirects for user name/password transmission. > > 2. If you wish to access the site without using the ProjectPoint client, you > remove "client" from the URL: > http://folders.buzzsaw.com/site > http://projectpoint.buzsaw.com/site > > 3. When I wish to access my site using WebDAV, I use "file open" in Internet > Explorer, and I make sure to check the box for "open as web folder" and I > use the URL: > https://webfolders.buzzsaw.com > The WebDAV protocol always uses https - even for file transfers. If you use > http instead of https, I think it will redirect. I don't think > webdav.buzzsaw.com is a valid URL. What happens when you try to open your > site from the browser instead of the application. If you can get it to work > from the browser, then we can look at what's going on in your application. > Maybe its that "open as web folder" part that must be set somewhere in your > code? > > "Timothy" wrote in message > news:2533430.1091501125638.JavaMail.jive@jiveforum1.autodesk.com... > > I have tried all of the following: > > https://webfolders.buzzsaw.com/Site > > http://webfolders.buzzsaw.com/Site > > https://webdav.buzzsaw.com/Site > > http://webdav.buzzsaw.com/Site > > https://folders.buzzsaw.com/Site > > http://folders.buzzsaw.com/Site > > > > All return an error. > > > > Tim > >
Sorry but I am not familiar with the API error code. "john bartak" wrote in message news:4123c5da_1@newsprd01... > Do you know that the error is caused by the login code? Could the error be > somewhere else in the code?
oPPFolder you are trying to access is actually a Buzzsaw project ? Declare oPPFolder as PPProject. It is most likely the case here.
