BIM 360 Glue Forum
Welcome to Autodesk’s BIM 360 Glue Forums. Share your knowledge, ask questions, and explore popular BIM 360 Glue topics.
Too Many Clashes Selected
1 REPLY 1
aedgar
402 Views, 1 Reply
When using the new and improved clash tools in Glue (great improvements by the way), I ran into an interesting problem.  I have many auto generated clash groups that contain thousands of clashes each and I am currently unable to change the clash status of these groups.  When I try I get an error that reads "Too many clashes selected.  No more than 200 clashes may be ignored at once.  Please select fewer clashes and try again."  I receive a nearly identical error if I try to close more than 200 clashes at once.
Is there a reason I can only change clash status 200 clashes at a time?
I ask because I have a project where electrical penetrations through a slab account for 1,262 clashes.  After quickly viewing these clashes I'd like to set them to ignored or closed because these items should penetrate the slab.  This could be two clicks to close or ignore, but with the 200 clash limit I have to click the check box by 200 clashes then ignore seven times.  It seems to me that I should be able to accomplish this task with 2 clicks not 1,269.
Is there a setting to change this behavior that I have missed?
Thanks in advance.
1 REPLY 1
anil_mistry
in reply to: aedgar
Hello Alex,
Thank you for participating in our community!
Currently it is by design that only 200 clashes can be ignored at a time. If you have any feedback that you would like to submit regarding any enhancement, please click on the “BIM 360 IdeaStation” link on the BIM 360 community home page.  This will help the Project Manager and developers hear your voice on any changes/concerns with functionality directly for consideration in future builds.
Please, let me know if this help.
Thank you and have a great day!
Best regards,
Anil Mistry
Technical Support Specialist
