Is there a way to select elements using a window instead of individually picking each element?
I understand that you want to you want to select an elements using window instead picking individually. At this time the Autodesk BIM 360 Glue do not allow window selection but if you select an object and view properties you can then right click and choose Select Similar.
Please, let me know if this help.
Thank you and have a great day!
Best regards,
