Hi, I am having real issues with merging some multi-discipline models in Glue. I am using Revit 2015's sample files (Technical School) as an example/presentation on benefits of Glue & Field. But my models when merged in glue are all mis-aligned. The transform option for each has same exact set of co-ordinates for x,y,z etc (see images showing MEP and Architectural merge). So moving/aligning is very difficult. I have set the models in revit to link via shared co-ordinates (glued with shared co-ordinates) models seem correct (when linked in revit). Can anyone please help? Is there something i need to perform before Gluing? Thanks!
Colin
Hello Colin,
Thank you for participating in our community!
I understand that when attempt to merge the Autodesk Revit Model in the Autodesk BIM 360 Glue your models do not align. I am sorry to hear that you are experiencing trouble with the application. We are aware of the issue and engineering has a fix that will be released very soon. As workaround align your model manually and enter the shared coordinates manually within the Glue application. You can submit a support ticket by clicking on “Contact Autodesk” link from the pull down (see attached) if you need additional assistance.
Please, let me know if this help.
Thank you and have a great day!
Best regards,
Shared coordinates issue you reported is fixed now and updated add-ins are now available. When you launch your application you will get an update and it will update automatic.
Best regards,
