So I tried the new Library Preview, and it seems to have a lot of bugs related to the tagging feature. I also discovered that the iPad app still works on the old Folder system, even though the new Library system seems to work off only tags, not folders.
I now have a library filled with a thousand unorganized files. How do I mass delete documents from the Library, so I can reupload them using the old Library interface?
Hello Justin,
Thank you for participating in our community!
We are aware of the tagging feature issue and engineering has a fix that will be released soon.
To answer your second question I would suggest trying delete files or folders from the old library viewer. In the new library viewer, you should be able to multi-select documents and then delete or search by a key word and then do a multi select and delete.
Please, let me know if this help.
Thank you and have a great day!
Best regards,
