Yes/No fields in BIM 360 Field seem to only import back into Revit as 'Yes'.
Thank you for participating in our community!
In order to answer your question I would like to know your workflow. What excately are you trying to do? What Pareametres are you trying to bring it back to the Autodesk Revit? Are you using BIM 360 add-ins?
Thank you and I look forward to your reply!
Best regards,
I'm trying to bring back a custom Yes/No field. I upload the model to Glue using the Revit plug-in, bring it over to Field, use the Revit plug-in to bring the parameters back in to the Revit model. The Yes/No parameters all show up as 'Yes' even if they are marked as 'No' in Field.
