• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Wiretap
    New Member
    Viewing or exporting files from isilon storage into stones
    130 Views, 2 Replies
    09-24-2007 10:33 AM
    Is there an SDK or third party application that make use of Wiretap to view and retrieve files from an Isilon Cluster on which all 2 D and 3D elements resides.
    Please use plain text.
    Valued Contributor
    Re: Viewing or exporting files from isilon storage into stones
    09-24-2007 05:56 PM in reply to: michel
    What file format and file system is the Isilon?
    New Member
    09-25-2007 11:45 AM in reply to: michel
    Isilon clustered storage system architecture consists of independent nodes that are all integrated with the OneFS operating system software. The systems can be installed in standard data center environments and are accessible to users and applications running Windows, Unix/Linux and Mac operating systems using industry standard file sharing protocols over standard Gigabit Ethernets.
    Nodes within the clustered storage system communicate with each other over a dedicated back-end network which is either Infiniband or standard Gigabit Ethernet. The architecture is designed so that each node has full visibility and write/read access to or from a single expandable file system.
    The core technology of the Isilon clustered storage consists of OneFS, which provides a single unified operating system and delivers up to 10 GB/s of throughput. The OneFS operating system software is designed with file-striping functionality across each node in a cluster, a fully distributed lock manager, caching, fully-distributed meta-data, and a remote block manager to maintain global coherency and synchronization across the cluster.
