• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Wiretap
    New Member
    Trying to export on WTC and can't get it.
    1315 Views, 1 Replies
    01-26-2009 10:01 AM
    Hi everyone... I recently hooked my box up to my wireless router again so that I could use wiretap. Now, I can go through all of the sorting and selecting of the clips that I want on the framestore, but when I go to export the clips from the playlist, it immediately says "encoding complete" and jumps to the next window which says: NOT FOUND The requested URL /WiretapCentral/export/asdfosdf_gce9jlo2/ was not found on this server.
    Can anyone give me some advice as to what might be wrong with my setup?
    Please use plain text.
    Valued Contributor
    Re: Trying to export on WTC and can't get it.
    01-26-2009 07:10 PM in reply to: j0shwink
    The URL you quoted is for the export package just created (i.e. the directory in which the exported clips are stored). The fact that it's not found is indeed confusing. I suggest you examine the apache logs on the WiretapCentral server: /var/log/http/error_log
    HTH,
    Dan
