• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Wiretap
    Member
    Trouble Compiling SDK
    115 Views, 1 Replies
    01-30-2008 02:45 PM
    I have been trying to recompile the .cpp including in the SDK for python2.4 support.
    Once I finally was able to get it to compile, I ended up with the following:
    4184 libwiretapPythonClientAPI.so
    4573538 lib/opt/LINUX/i686/RHEL4/GCC_3_4_4/libwiretapClientAPI.a
    2648825 lib/opt/LINUX/i686/RHEL4/GCC_3_4_4/libwiretapClientAPI.so
    2980394 lib/opt/LINUX/i686/RHEL4/GCC_3_4_4/libwiretapPythonClientAPI.so
    I have added this lib path, as well as my boost location (/usr/local/lib/boost-1_33_1) to my environ variable LD_LIBRARY_PATH, and tried to import libwiretapPythonClientAPI.so
    I get the following error:
    >>> from libwiretapPythonClientAPI import *
    Traceback (most recent call last):
    File "", line 1, in ?
    ImportError: dynamic module does not define init function (initlibwiretapPythonClientAPI)
    I am able to use the supplied python2.3 .so just fine, but I need it for 2.4
    Could anyone offer specific information on how to properly recompile the SDK?
    Thanks!
    Please use plain text.
    Distinguished Contributor
    Re: Trouble Compiling SDK
    01-31-2008 04:49 PM in reply to: jdisrael
    I suggest you use "nm -C" (on linux) to list the symbols. My guess is that your link line is to blame. Here's the one we use:
    g++ -m32 -O3 -shared --whole-archive -Bdynamic -o libwiretapPythonClientAPI.so wiretapPythonClientAPI.o libwiretapClientAPI.a libboost_python.a
    Not ethat we link against the static WT API lib
    HTH,
    Dan
