Autodesk Wiretap
Topic Options
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Problem with Switchable Storage
Options
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
146 Views, 4 Replies
05-17-2007 01:35 PM
When transferring a QT to a Switchable Stone, the result clip is garbled noise. When transferring the same file to local storage on IBM 6221 2007 SP3 or SGI 9.5, the result is fine.
Done with tether.
Alan
Done with tether.
Alan
Re: Problem with Switchable Storage
Options
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
05-18-2007 04:48 AM in reply to:
alatteri
Hi Alan,
Switchable Storage has no effect on Wiretap. Once a storage switch is made, the system behaves exactly as though the Stone were direct-attached. The problem is likely somewhere else.
The best way to know where the problem lies (WT or Tether) is to use WT Web to visualize the images, since it uses the WT API to create jpg versions of the images.
Dan
Dan
Options
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
05-18-2007 08:47 AM in reply to:
alatteri
The problem is not seeing the Stone properly, tether is doing that fine, and shows the same garbage as the Smoke Player.
This is from my client:
"Of note I did get Tether to work once. However, that was before discreet "fixed" antoher problem we where having. When we upgraded to Smoke 2007 we realized discreet had never tested switchable storage, Smoke 2007, and SGI. Therefore when we upgraded switching became very long. Discreet made a patch that made that process faster, however it seems to have had a negative effect on Tether."
I am still diagnosing on my side.
Options
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
05-18-2007 10:06 AM in reply to:
alatteri
I'm not at all sure what you're trying to say here.
Switchable Storage Customers tend to have VERY complex setups, usually involving combinations of Stone and Soft-imported workflows.
Options
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
05-18-2007 12:04 PM in reply to:
alatteri
Seems to be a Codec issue on the persons Mac.
