• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Wiretap
    New Member
    Offset timecode on EVERY XML import
    1370 Views, 1 Replies
    07-14-2009 08:02 AM
    Hello
    I am trying to use Wiretap for the first time to conform RED footage from a Final Cut XML.
    Each time I import the XML to Wiretap it imports with an offset and incorrect timecode.
    I have imported the XML back into Final Cut to check the in/out timecodes for each clip. When I do this it matched the Final Cut project.
    When I import the same XML file into Wiretap all of the timecodes have become offset.
    Any ideas would be great as I am banging my head on this one!
    cheers
    dK
    Please use plain text.
    Member
    Re: Offset timecode on EVERY XML import
    07-14-2009 09:56 PM in reply to: motorvfx
    hi
    In wiretapcentral while u r in submit tab check whether the handles given matches the same handles used while exporting from FCP.
    Then in smoke after u import the xml file select it and the go to tools and in tools select consolidate, where give the same handles used in fcp.
    And then consolidate it.
    Probably this should solve the problem.
    Cheers
