• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Wiretap
    Member
    File ownership on new projects
    87 Views, 3 Replies
    11-12-2007 05:50 AM
    If I create a PROJECT node, the project directories created under /usr/discreet/project are all owned by root rather than the flame user, which causes problems for our project management system (I really don't want it to run as root). In particular the project's config file by default is only writable by root.
    Is there anyway to change this? If not, could you consider it for a future version?
    Please use plain text.
    Valued Contributor
    Re: File ownership on new projects
    11-12-2007 08:22 PM in reply to: ciaran2
    What version do you have? I'm quite sure that flame/smoke can properly edit/delete any project created via Wiretap. Can you confirm this?
    Can you elaborate as to what you are trying to do? I'm pretty sure you should be able to do everything exclusively via Wiretap ... include editing project configration files.
    Member
    11-12-2007 10:36 PM in reply to: ciaran2
    Flame can, because it runs suid, but my project management software can't, as it runs as the flame login user.
    What I'm doing is incrementally update software that moved projects around outside of flame to use wiretap where possible
    Is it possible to edit the /usr/discreet/project//cfg/.cfg file through wiretap? Admittedly I haven't tried that yet.
    Valued Contributor
    11-13-2007 04:57 AM in reply to: ciaran2
    Ah ... makes sense now.
    Wiretap 2008 is designed to allow you to access all project-related metadata through Wiretap. i.e. You shouldn't need to access anything via direct paths anymore.
    The project.cfg, for example, is exposed as raw metadata on one of the setup nodes in the project. You can use the WireTapMetadataBlob class to extract it.
