• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Autodesk Wiretap
    Valued Contributor
    Burn question.
    89 Views, 2 Replies
    10-03-2007 11:49 PM
    Hey,
    Since the sparks-dev forum no longer exists I am posting here. We are working on a spark, and need to test how it behaves in burn. I would rather not have to get yet another separate machine for that. Can I run IFFFS and Burn on the same machine?
    Alan
    Please use plain text.
    Valued Contributor
    Re: Burn question.
    10-04-2007 04:58 AM in reply to: alatteri
    Hi Alan,
    At the very least, you can definitely install everything on the same machine and run burn/flame alternately to verify your results.
    Dan
    Valued Contributor
    Re: Burn question.
    10-15-2007 07:08 AM in reply to: alatteri
    Does Burn 2007 run on 32 bit processors, specifically the IBM 6221?
    Alan
