• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Vault
    Member
    Lalatorre
    Accepted Solution
    question with how vault data works
    84 Views, 4 Replies
    02-22-2012 03:52 PM
    Hi my question is how vault manage the files and models, for example, if my files are stored in the server, when i open this files, a temporal copy is created in my computer to work?  can i have two file storage servers on diferent places, and if i need to work in place1 take the model in the server1, and if i work in the place2 take the model in the server2? can this work with a VPN on diferent countries?
    Tanks a lot.
    Board Manager
    Re: question with how vault data works
    02-23-2012 07:21 AM in reply to: Lalatorre
    Different versions of the files are stored on the server as you or your users check files in.  When you check a file out of Vault, a copy of the file is placed in your workspace on your computer for you to do your work.  Depending on your Vault install configuration, you could have a multi-site environment, 2 servers 1 database, where you can start your work at location 1 but check it in at location 2 from the same workstation.  As long as you have access to a Vault server, you can use vault.  This can be from VPN or opening the necessary ports through your firewall to allow access to the Vault server.
    Irvin Hayes Jr
    Product Manager
    Autodesk, Inc.
    Member
    Lalatorre
    02-23-2012 08:02 AM in reply to: Lalatorre
    ok, and can i have two redundant servers in two different offices or countries for example, and vault take the files from the closer server to do quickly the workflow?? the different offices process diferent models, but i want to at the end of the day the two servers are synchronized.
    Board Manager
    02-23-2012 08:04 AM in reply to: Lalatorre
    The Vault Collaboration or Professtional editions offer a full replication feature that should help you with your needs.  Contact your Autodesk reseller to assist and for further understanding your needs.
    Irvin Hayes Jr
    Product Manager
    Autodesk, Inc.
    Member
    Lalatorre
    02-23-2012 08:29 AM in reply to: ihayesjr
    ok! now i have a better idea, i'll find my reseller. thanks!
