• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Vault
    Active Member
    not possible to checkout many data at once
    215 Views, 8 Replies
    01-17-2011 04:49 AM
    Hi all, if I try to checkout a folder with many data and dependencies, the windows "freezes". Normaly the OK-button should angray after the progress-bar has disappeared, it stays disabled. It's not a new problem, I have it for a long time now. Is there already a solution? (I'm using Vault 2011 SP2)
    Please use plain text.
    Active Member
    Re: not possible to checkout many data at once
    01-24-2011 10:22 AM in reply to: ich.mts
    any news? Does no one have an idea? Should I contact the support by mail?
    Active Member
    04-14-2012 07:26 AM in reply to: ich.mts
    Hi all,
    I still have the problem, that I cannot check-out larger forlders! Is there nobody else with this problem?
    I can reproduces the on every client-pc. I have installed all hotfixes
    Employee
    04-16-2012 08:56 AM in reply to: ich.mts
    Hello. I'm sorry to hear you're having this issue. Can you give us an idea of approximately how many files you're attempting to download? This will help give us a good idea of what you're working with.
    Adam
    Adam Luttenbacher
    Sr User Experience Designer
    Autodesk, Inc.
    Active Member
    04-16-2012 09:03 AM in reply to: ich.mts
    the problems start at about 1000 files. On the other hand I can download the complete vault without any problems.
    By the way: I have the german version and with "checkout" I mean "Abrufen / Auschecken".
    Employee
    04-16-2012 10:45 AM in reply to: ich.mts
    Interesting. Just to clarify, you are seeing this on more than one machine?
    If you were seeing it on one machine, I would guess that the problem is that the dialog has populated on a second screen. I see that issue come up often. The dialog is off the screen when only one screen is viewable.
    Do you think that's an option here? Are you using multiple monitors?
    Adam
    Adam Luttenbacher
    Autodesk, Inc.
    Active Member
    04-16-2012 11:30 AM in reply to: luttena
    The problem is 100% reproducible and happens on all machines (also machines with 4 screens).
    I can even see the checkout-dialog and the software is not freezed, but the ok-button is disabled so I cannot continue.
    *Expert Elite*
    cbenner
    04-16-2012 11:56 AM in reply to: ich.mts
    I just tested this on a folder with over 1,600 files and it worked ok.  What are your computer/network specs?  Perhaps the problem is hardware related?
    ChrisB
    Please use Mark Solutions!.Accept as Solution &Give Kudos!Kudos to further enhance the value of these forums. Thank you! :smileyhappy:
    Active Member
    04-16-2012 11:59 AM in reply to: cbenner
    it's definitely not hardware-related!
    I'm actually sitting on a i7 860 with 8GB RAM, 1Gbit LAN.
    The Vault-server is installed on a i7 950 with 24GB RAM, 10Gbit LAN.
