• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Vault
    Employee
    Re: Windows Authentication component broke???
    03-20-2012 07:56 AM in reply to: lypatric
    If it works via IP address and not the host name then your issue is most likely a network issue.
    If you do a "ping <hostname>" do you get the same IP address?  Check with your IT group for help with this.
    Hywell Herrero
    Data Management Support Specialist
    Product Support
    Please use plain text.
    03-21-2012 04:29 AM in reply to: hherrero
    Thanks for reply.
    The "ping" works, with IP address or server name.
    New Member
    02-26-2013 08:03 AM in reply to: lypatric
    Hi!
    is there a step by step guide for reinstalling the IIS?
    I have the same problem after installing sp2 for Vault Pro 2012.
    The IIS roles are configured corectly, so I must reinstall the iis.
    Thanks.
    Fotis
