• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Vault
    m.numberger
    Accepted Solution
    Who has a licence?
    529 Views, 14 Replies
    02-16-2012 12:12 AM
    with lmutil_x64.exe lmstat -a -c @server i can see which user has a Inventor-licence, but not who has a Vault-licence. You see only how many Vault-licence are in use.
    How can i see who has a Vault-licence?
    Best regards
    Michael
    Please use plain text.
    *Expert Elite*
    DarrenP
    Re: Who has a licence?
    02-16-2012 06:17 AM in reply to: m.numberger
    you should be able to run a status inquiry on flex lm
    m.numberger
    02-16-2012 07:16 AM in reply to: DarrenP
    do you mean the function in the LMTools > Server Status > Perform Status Enquiry?
    This shows me the same.
    User of the Vailt-Licence is always the Server, you can not see wihich client has the licence.
    *Expert Elite*
    DarrenP
    02-16-2012 07:17 AM in reply to: m.numberger
    thats right
    i don't think you can with vault since the licensing works differently
    02-16-2012 08:39 AM in reply to: m.numberger
    When a user connects to Vault, it is the ADMS that get's the license, and then provides connectivity to the client.
    *Expert Elite*
    DarrenP
    02-16-2012 08:41 AM in reply to: CodeMonkey831
    yep thats correct
    Distinguished Mentor
    02-16-2012 10:56 AM in reply to: m.numberger
    If I remember right, one of the ADMS log files records license status.  You might be able to write a script that scans throught the file and gives you a nice list of who has a license.
    I am not aware of a nice list from ADMS about which users are consuming a license.
    m.numberger
    Betreff: Who has a licence?
    02-16-2012 10:18 PM in reply to: m.numberger
    thanks for your answer.
    I found the log-Files.
    If anybody search this: Every day is made a new log-file under:
    C:\ProgramData\Autodesk\VaultServer\FileStore with the name vlog-20120217.txt par example.
    Best regards
    Michael
    m.numberger
    02-26-2012 01:36 AM in reply to: m.numberger
    i made a WSH-script to read out the which users has a Vault license in use.
    On the server you have to share the Folder C:\ProgramData\Autodesk\VaultServer\FileStore
    I start this with a Batch-script, in this i read out with other FlexLM-License are in use.
    if you want to use this in a batch file, you can start ist with "cscript.exe vault-license.vbs" an the output comes on the command line.
    Best regards
    Michael
    Distinguished Contributor uma
    03-05-2013 11:50 PM in reply to: m.numberger
    Being placed to "C:\ProgramData\Autodesk\VaultServer\FileStore" of ADMS and executed it reports "Pfad nicht gefunden" which I guess means "Path not found".
    So there are a lots of vlogs just around but it can't see them...
    Any ideas?
    ...Added later....
    Ok I've fixed it a bit
    instead
    PfadLogfile = "\\SERVER\FileStore\"
    printed
    PfadLogfile = "C:\ProgramData\Autodesk\VaultServer\FileStore"
    And it returned the list of successful attempts for license.
    But it is not the list of users who use license right now. Isn't it?
