Autodesk Vault
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Printer Friendly Page
Whats a *.v file?
- Highlight
- Email to a Friend
When I get (not checkout) files off a vault; why ithere a .v file thats dumped into my working folder. What is this? I dont see this in the vault though.
Inventor Professional 2013
Vault Collaboration 2013
Re: Whats a *.v file?
- Highlight
- Email to a Friend
I think its new for 2012, its a hidden folder, so i suspect the developers didn't expect most people to see it. I would also like to know its exact purpose.
From memory its empty, but i'm guessing its some new way for Vault to keep track of which files are read-only or locked from Vaults point of view. Maybe the Vault Add-in needs it more than Vault explorer?
Autodesk?
- Highlight
- Email to a Friend
Please refer File Resolution Updates in 2012 video from the following link.
The files can be renamed / moved quickly in Vault Explorer in 2012. This is because, the parents (assembly/drawings) are not repaired at the time of move or rename. But the parents will be repaired at the time of download.
During Get / Checkout (From VE / Inventor / AutoCAD), the file references will be fixed even before it is opened. When the file reference is changed, Vault will treat the parent file as edited out of turn. But this is not the desired status when the file is opened from Vault. So, changes (difference between original file and the changes due to updated reference) will be captured in a companion file which is called .V file that will be located under _V folder of the parents’ folder. The Vault status will be corrected based on the information from companion file.
For example,
If Assembly1.iam is downloaded to C:\Work\Designs, the location of .v file is C:\Work\Designs\_V\Assembly1.iam.v
For more information, please refer
http://justonesandzeros.typepad.com/blog/2011/05/f
Hope that helps.
Madhan
Madhanagopal Thiruvenkatachalam
Support Specialist
Product Support
Autodesk, Inc.
- Highlight
- Email to a Friend
- Highlight
- Email to a Friend
Madhan,
Thanks for the link & the explanation.
- Highlight
- Email to a Friend
Welcome, and Cheers!!!
Madhan
Support Specialist
Product Support
Autodesk, Inc.
- Highlight
- Email to a Friend
So, it appears that its safe to delete the this folder "_V" and all its contents.
any body doing this?
- Highlight
- Email to a Friend
If you delete those files you will likely end up with many files with a vault status of "edited out of turn". I would not recommend deleting them.
-Dave
Dave Mink
Data Management
Autodesk, Inc.
- Highlight
- Email to a Friend
