• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Vault
    Vault server installation failing
    134 Views, 3 Replies
    10-15-2011 04:00 AM
    I have been trying to install Vault server and it is failing with the following message: "Install AMS Check. Failed Installation aborted, Result = 2"l .   What could be the reason for this message?
    Please use plain text.
    Employee
    chearhuat
    Re: Vault server installation failing
    10-16-2011 08:01 PM in reply to: tmccar
    Hi tmccar,
    During the ADMS pre-check prior to installation, we will list the causes, and possible solution to those errors.
    Could you help to examine those?
    Also, if you could, please send us the log file in %temp folder, that'll help us to do troubleshooting too...
    thanks :smileyhappy:
    Chear Huat.
    Chear Huat
    SQA Analyst
    DLS- Data Management
    Be sure to check out the Vault Help Wiki!
    10-17-2011 02:06 AM in reply to: chearhuat
    Hi
      When running the System readiness checks, it is failing with the message "ASPX file failed to run at  "locahost/testASP/TestASPNet.aspx".
     If I try to open that link in a browser, I get the error message "
    Handler "PageHandlerFactory-Integrated" has a bad module "ManagedPipelineHandler" in its module list"
    10-17-2011 04:26 AM in reply to: tmccar
    OK, it's now installing fine. I got  working by uninstalling IIS and also renaming the "c:\inetpubb\wwwroot" folder. I ran the 2012 Vault server installation and let it do the IIS installation, and create the "wwwroot" folder.
