• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Vault
    Distinguished Contributor
    Vault ribbon menu missing for AutoCAD Mechanical 2012
    1242 Views, 10 Replies
    09-27-2011 09:48 AM
    My install of Product Design Suite Premium 2012 includes AutoCAD and AutoCAD Mechanical. In the AutoCAD profile ribbon menu thee is a Vault area. Thee is not one in the AutoCAD Mechanical ribbon menu. Is this on purpose? To check files in/out in AutoCAD Mechanical it appears I must use the drop down menu.
    Please use plain text.
    Employee
    Senthil-Autodesk
    Re: Vault ribbon menu missing for AutoCAD Mechanical 2012
    09-28-2011 07:24 PM in reply to: tahdesign
    Hi
    The following information is from Readme. Can you please try this and see if you can get the Vault Tab in the ribbon?
    • The Vault ribbon and toolbar may be missing when launching AutoCAD and AutoCAD-based products from the same installation but using different profiles. To restore the Vault ribbon and toolbar, enter CUILOAD and load the "VaAc.cuix" file from the respective locations:
      • For Windows XP - C:\Documents and Settings\ [username] \Application Data\Autodesk\ [product name] \R18.1\ [lang] \Support
      • For Windows 7 and Vista - C:\Users\ [username] \AppData\Roaming\Autodesk\ [product name] \R18.1\ [lang] \Support
    Senthil Kumar
    Sr QA Analyst
    Be sure to check out the Vault Help Wiki!
    Distinguished Contributor uma
    06-11-2012 12:49 AM in reply to: tahdesign
    We have same issue at least on several PCs and there is no "VaAc.cuix" on the disk C at all.
    Both Vault Pro and ACADM were reinstalled several times. What might be wrong?
    Employee
    Senthil-Autodesk
    06-11-2012 02:00 AM in reply to: uma
    What is your order of installation? Try this order and let us know how that goes.
    1. Install ACADM
    2. Install Vault Professional Client.
    If you have the order in reverse way then try the following
    1. Go to Control Pane->Add Remove Programs
    2. Select Vault Pro Client - Add/Remove Features and then check whether AutoCAD Mechanical Add-in was selected or not. If not select and install
    One of the above should help you to get the Vault add-in inside ACADM. Let us know if you cannot see the add-in still.
    Senthil Kumar
    Sr QA Analyst
    06-11-2012 02:52 AM in reply to: Senthil-Autodesk
    The key problem is:
    In our product set Vault Pro 2012 Client installer is supposed to show at least 7 features in list of features :
    1. Autoloader
    2. AutoCAD Mechanical 2012 Add-In
    3. AutoCAD Electrical 2012 Add-In
    4. Autodesk Inventor 2012 Add-In
    5. MS Office Add-In
    6. MS Outlook Add-In
    7. Samples
    (source - http://www.cadlinecommunity.co.uk/Blogs/Blog.aspx?ScoId=afdf3378-a0dc-42b3-8c19-859c455a1f05, we don't have  AutoCAD Architecture)
    But insted it shows only 4:
    1. Autoloader
    2. Autodesk Inventor 2012 Add-In
    3. MS Office Add-In
    4. Samples
    I wonder where is the rest? And how to make Vault Pro 2012 Installer  see them?
    Employee
    Senthil-Autodesk
    06-11-2012 03:02 AM in reply to: uma
    Thanks for your reply.
    Do you have the following installed and ran atleast once in that machine?
    • AutoCAD Mechanical 2012
    • AutoCAD Electrical 2012
    • MS Outlook
    Also did you try uninstalling and installing just Vault Pro 2012 alone? If possible please send me the screenshot of your installed programs from the add/remove programs list.
    Senthil Kumar
    Sr QA Analyst
    Member
    12-05-2012 04:50 AM in reply to: Senthil-Autodesk
    I have similar problem with PrDS 2013 on several machines. On three of them Vault Client installation "see" only AutoCAD Mechanical, and doesn't see AutoCAD Electrical at all. On fourth machine installer was able to install add-in on Electrical, but not Mechanical.
    I tried every possible combination - I uninstalled Mechanical to check, if Vault installer will see Electrical. Obviously Electrical was started and closed befor Vault installation, but nothing helps. Installer somehow chooses some AutoCAD and shows it on the list to install.
    Can anybody help me to add Vault Workgroup add-in to my Electrical or Mechanical? I can load cui, but application component are also needed to be loaded to AutoCAD.
    Thanks for any idea.
    12-05-2012 05:15 AM in reply to: tahdesign
    The UI language of your CAD installed should comply with language of Vault Client.
    In some configurations you need to install two Vault clients of different languages ie (Pro and Basic).
    Member
    12-05-2012 06:12 AM in reply to: uma
    Thank you for the hint. Indeed, the problem has something to do with languages, because english Vault installer sees Electrical and polish Vault installer sees Mechanical (polish). Should I install two Vault Workgroup clients in two languages on the same machine? Is this possible?
    12-05-2012 06:18 AM in reply to: anna.nowak
    So you probably use English Electrical and Polish Mechanical. Unfortunately Vault unlike Inventor does not support installing the same client in two languages on same PC but you can install Polish Vault Workgroup  and English Vault Basic. This should help. We do so with English and Russian.
