• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Vault
    Member
    gblackwo
    Vault configuration issue
    101 Views, 2 Replies
    02-22-2012 02:41 PM
    I have Vault set-up on my server at home. The router is configured to pass through on port 80. I am able to log into Vault from within the server, and from other machines on the local network. Outside of the network, IIS is visible- feel free to have a look: http://184.17.89.171/ But when I try to log into Vault from outside the network- I constantly get the "server not found" message. I figured if I can see IIS, and AutodeskDM then it Inventor should be able to log in. Is there a configuration I am overlooking that would allow local network users to log-in but exclude external users, even though external users can successfully see IIS on the machine? Thanks,
    Member
    gblackwo
    Re: Vault configuration issue
    02-22-2012 08:58 PM in reply to: gblackwo
    I'm going to shut down the server for tonight. So the link I posted previously will be dead. I'm still looking for solutions on this however. Thanks,
    Member
    gblackwo
    02-23-2012 03:29 PM in reply to: gblackwo
    I've still not found a solution.
    I suspected it is a firewall issue, however communication with ISS on port 80 is not an issue.
