• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Vault
    Active Contributor
    Accepted Solution
    Vault collaboration and 3ds Max
    755 Views, 30 Replies
    02-11-2011 06:43 AM
    Simple question - can't seem to find any information that 3ds Max has an addin for VC, is that true? I think files can be added manually, however I concerned with an account that needs to deploy 3ds Max and VC 2011 in a full replication configuration. Concern is the 3ds Max and the effect of a manual add to the Vault?
    Thanks all
    mb
    Please use plain text.
    Board Manager
    Re: Vault collaboration and 3ds Max
    02-11-2011 10:29 AM in reply to: mbaker
    MB,
    Sorry but 3DS Max Vault add-in only works with our base Vault server which you can download through the subscription center.  It is not compatible with Vault Collaboration.
    Irvin
    Irvin Hayes Jr
    Product Manager
    Autodesk, Inc.
    Active Contributor
    02-11-2011 10:38 AM in reply to: ihayesjr
    HI Irvin,
    OK I think? It would seem that we need to do something for 3ds users whose teams are using the Collaboration tools. So only process is the add the 3ds models manually from the Vault Client application? Yes
    Mb
    Board Manager
    02-11-2011 10:42 AM in reply to: mbaker
    You are correct.  The only solution available for you is to add the files manually with the Vault client application.  I will forward your needs along to see what we can do in the future.
    Irvin Hayes Jr
    Product Manager
    Autodesk, Inc.
    Active Contributor
    02-11-2011 10:46 AM in reply to: ihayesjr
    Irvin - Thanks that helped...
    Mike
    Board Manager
    02-11-2011 10:49 AM in reply to: mbaker
    Mike,
    Have you downloaded the Vault add-in from the subscription center?
    Irvin Hayes Jr
    Product Manager
    Autodesk, Inc.
    *Expert Elite*
    DarrenP
    02-11-2011 10:53 AM in reply to: ihayesjr
    the vault add in for max comes with the max installation not with the vault client add in
    *Expert Elite*
    DarrenP
    02-11-2011 10:55 AM in reply to: DarrenP
    see screenshot:
    *Expert Elite*
    DarrenP
    02-11-2011 10:57 AM in reply to: DarrenP
    from the subscription site: Note for 3ds Max and 3ds Max Design Users: You must install the Autodesk Vault 2011 Plug-in for 3ds Max 2011 from the 3ds Max or 3ds Max Design 2011 Installation Wizard to make Vault available from within the product.
    the max design 2011 install wizard doesn't come the vault 2011 add in as you can see from the screen shot above
    Board Manager
    02-11-2011 12:02 PM in reply to: DarrenP
    Mike,
    Use Darren's suggestion to get the Vault add-in installed and that add-in should connect to the Collaboration server.
    Irvin Hayes Jr
    Product Manager
    Autodesk, Inc.
