• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Vault
    Accepted Solution
    Vault Server 2012 on 64-bit PC
    445 Views, 7 Replies
    08-22-2011 07:39 AM
    Can l Vault 2012 Pro Server be installed on a 64-bit system?  I'm guessing not, because I am getting this error message when I try:
    "An attempt was made to load a program with an incorrect format"
    Please use plain text.
    Employee
    chearhuat
    Re: Vault Server 2012 on 64-bit PC
    08-23-2011 02:03 AM in reply to: tmccar
    Hi tmccar,
    Vault Server 2012 can be installed on a 64-bit PC. Nonetheless, it will be installed as a 32-bit application.
    To guide us in troubleshooting, it will be good if you could provide us with the following info:
    i. the OS of the 64bit machnie
    ii. the installation log file (could be found in folder %temp%, the latest log file)
    Chear Huat.
    Chear Huat
    SQA Analyst
    DLS- Data Management
    Autodesk, Inc.
    Be sure to check out the Vault Help Wiki!
    08-23-2011 05:27 AM in reply to: chearhuat
    Hi Chear
       The OS is Windows 7 and it was installed in Denmark
    When doing an install of SQL Server 2008 R2, it fails at the followig check:
    "Performance counter registry hive consistency"
    Tom
    Employee
    08-23-2011 06:24 AM in reply to: tmccar
    Try rebuilding your peformance coutners using the following:
    • Start -> Run
    • cmd.exe
    • cd C:\Windows\System32
    • lodctr /R
    Once the performance counters are rebuilt, try the installation of SQL 2008 R2 again.
    -Hywell
    Hywell Herrero
    Data Management Support Specialist
    Product Support
    Autodesk, Inc.
    08-23-2011 06:53 AM in reply to: hherrero
    Yes i did that but it's still giving the error
    08-23-2011 10:01 AM in reply to: tmccar
    Employee
    chearhuat
    08-25-2011 12:42 AM in reply to: tmccar
    Hi tmccar,
    Could you share with us the exact workaround you adopt in ur solution? That'll help to benefit the forum users...
    Thanks :smileyhappy:
    Chear Huat.
    Chear Huat
    SQA Analyst
    Autodesk, Inc.
    08-25-2011 03:53 AM in reply to: chearhuat
    The SQL Server 2008 install was failing the "performance counter hive consistency" check.
    The laptop is a localised Denmark build.
     I exported the following regiatry key:
        HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Perflib\009
    006 is the code for Denmark, so I edited this .reg file (changed the 009 to 006) re-imported it and the SQL installation .completed.
