Autodesk Vault
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Vault Server 2012 on 64-bit PC
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Can l Vault 2012 Pro Server be installed on a 64-bit system? I'm guessing not, because I am getting this error message when I try:
"An attempt was made to load a program with an incorrect format"
Re: Vault Server 2012 on 64-bit PC
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Hi tmccar,
Vault Server 2012 can be installed on a 64-bit PC. Nonetheless, it will be installed as a 32-bit application.
To guide us in troubleshooting, it will be good if you could provide us with the following info:
i. the OS of the 64bit machnie
ii. the installation log file (could be found in folder %temp%, the latest log file)
Chear Huat.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Hi Chear
The OS is Windows 7 and it was installed in Denmark
When doing an install of SQL Server 2008 R2, it fails at the followig check:
"Performance counter registry hive consistency"
Tom
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Try rebuilding your peformance coutners using the following:
- Start -> Run
- cmd.exe
- cd C:\Windows\System32
- lodctr /R
Once the performance counters are rebuilt, try the installation of SQL 2008 R2 again.
-Hywell
Hywell Herrero
Data Management Support Specialist
Product Support
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Yes i did that but it's still giving the error
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Found a solution/workaround here:
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Hi tmccar,
Could you share with us the exact workaround you adopt in ur solution? That'll help to benefit the forum users...
Thanks ![]()
Chear Huat.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
The SQL Server 2008 install was failing the "performance counter hive consistency" check.
The laptop is a localised Denmark build.
I exported the following regiatry key:
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Perflib\009
006 is the code for Denmark, so I edited this .reg file (changed the 009 to 006) re-imported it and the SQL installation .completed.
