Autodesk Vault
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Printer Friendly Page
Vault Revision in ACAD T-Block
- Highlight
- Email to a Friend
Is there any reason why, In ACAD 2013 (or any release), I cannot set a block attribute to a field that uses the File Property "Revision"? This property gets set by Vault with our lifecycles, and I can see it update on the drawing.... but it is not available as a field when setting up title block attributes. I use the Vault Rev table and that works just fine... but I want my revision in the titleblock as well....
any thoughts?
Re: Vault Revision in ACAD T-Block
- Highlight
- Email to a Friend
- Highlight
- Email to a Friend
Hey Chris,
If you are able to map and update the property correctly to the ACAD file properties but cannot reference this into a block attribute this is likely an AutoCAD limitation - you may have to make enquiries on their DG. Perhaps it is just the Revision property that is limited - you could test by mapping to another standard or custom file property in the DWG file.
For our part we can map most properties back to the AutoCAD file properties or directly to block attributes (You can write revision directly to an indexed block attribute). So if all else fails you can simply map the same revision property directly to your titleblock.
Hope this helps.
