• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Vault
    *Expert Elite*
    cbenner
    Accepted Solution
    Vault Revision Table
    215 Views, 6 Replies
    06-25-2012 11:47 AM
    Is anyone using the Vault Revision Table?  Vault Pro 2013 or anything close?  Have you gotten it to work?
    I have tried it with the default settings, and with picking standard and/or custom properties.  Every time in Inventor that I place a Vault Rev table, it comes in with the settings of my custom "regular" revision table.  What do I do to get the Vault table to come in using the properties I set up for it IN VAULT?
    ChrisB
    Please use Mark Solutions!.Accept as Solution &Give Kudos!Kudos to further enhance the value of these forums. Thank you! :smileyhappy:
    Please use plain text.
    Active Contributor
    Re: Vault Revision Table
    06-26-2012 02:43 AM in reply to: cbenner
    Think im making slow progress, havent gotten it to work but It's alot harder than it needs to be.
    it's not like every single drawing needs to be issued for construction needs a titleblock and rev table, but using civil 3d i might be dreaming.
    *Expert Elite*
    cbenner
    06-26-2012 07:56 AM in reply to: Mpendlebury
    From this thread I've gotten it close to working, just need to figure out why the Job Processor is looking at the wrong server.
    http://forums.autodesk.com/t5/Autodesk-Vault/Vault-2012-Revision-Table-Integration/td-p/3134818
    ChrisB
    Employee
    yingkit(Autodesk)
    06-28-2012 07:23 AM in reply to: cbenner
    Hi Chris,
    I would like to recommend this article "Setting Up Vault Revision Tables" which also includes a video clip.
    The Revision Table settings in Vault does not control the settings in the revision table that is placed in Inventor. Rather, we enter the exact words used in the drawings' revision table column for the Column Header value while configuring the Revision Table Settings.
    Kit
    Employee
    alan.ho
    06-28-2012 08:19 AM in reply to: cbenner
    Hi cbenner,
    Ying-Kit is right, the Vault revision table does not control the styles of the Inventor drawing.
    You would require to custom the Revision Table styles in the drawing templates within your workgroup.
    I have just posted a link on how this can be done:
    http://forums.autodesk.com/t5/Autodesk-Vault/Vault-revision-table-and-Autocad/m-p/3519888#M43147
    Hope this helps.
    Alan Ho
    User Experience Designer
    Design, Lifecycle, & Simulation
    Autodesk, Inc.
    *Expert Elite*
    cbenner
    06-28-2012 08:47 AM in reply to: alan.ho
    Thank you guys for your help,  I've managed to push through this challenge and got the table working.  That was a major hurdle in my DMS plans.
    ChrisB
    CAD-One
    07-02-2012 02:30 AM in reply to: cbenner
    Great tips. Useful information. Thanks
    C1
    Inventor Professional 2013
    Vault Collaboration 2013
