• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Vault
    Active Contributor
    Vault Pro Backups and MS SQL Server Guest Account for MSDB database
    185 Views, 1 Replies
    11-07-2012 12:49 PM
    In MS SQL Server their existing several system databases (master, model, msdb, tempdb).  During a customer IT security scan of the Vault SQL server it reported back a security hole.  For these system databases their exists a default SQL Guest account under their security settings.  This account raises as a security risk by the scanners.  The customer went and disabled this SQL Guest account for each of those system databases (as they have done for their other SQL servers), but this time for Vault, the Vault backups stopped working.  Once this SQL Guest account was reenabled the Vault backups continued to work again.
    My question is...does Autodesk Vault require this SQL Guest account to perform operations like the Vault backup and/or other operations?
    We found some documentation from MS that indicates that this may be some sort of bug in SQL 2008 and not to disable it.  But my customer wants to hear from Autodesk first on this issue!
    Thank you!
    John
    Please use plain text.
    Board Manager
    Re: Vault Pro Backups and MS SQL Server Guest Account for MSDB database
    11-07-2012 01:42 PM in reply to: jdow
    John,
    Vault doesn't require this account SQL does.  Please have your IT department use the SQL Management Studio and perform a backup of all databases through the studio.  You should have the same issue.
    See this article: http://support.microsoft.com/kb/2539091
    Irvin Hayes Jr
    Product Manager
