• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Vault
    Accepted Solution
    Vault Pro 2013 - Scheduled Backup Question
    292 Views, 6 Replies
    10-05-2012 07:23 AM
    I'm asking this on behalf of our IT department.
    They let Vault run its scheduled backups.  When it does, the file name seems to be a unique name that includes the date and time.  IT runs a backup on computer running Vault.  Those backups are already serialized by date.  So the serialized Vault backups are redundant.
    Is there any way to have Vault backup, preferably to a network drive, every night using the same file name for the backup?  If necessary, it could be to a local drive.  Using the same file name every time seems to be the key.
    Bill Schmid
    Autodesk Product Design Suite Premium 2013
    Autodesk Vault Professional 2013
    Dell Precision T1650
    Windows 7 Professional SP1 64-bit
    Intel E3-1270 V2 3.5GHz / 16G RAM
    Nvidia Quadro 2000, Driver 276.42
    256 GB SSD
    Space Navigator, Driver Version 6.16.1
    Please use plain text.
    Board Manager
    Re: Vault Pro 2013 - Scheduled Backup Question
    10-05-2012 08:09 AM in reply to: Bill.Schmid
    Sorry but currently the name of the backup folder is not configurable.
    Irvin Hayes Jr
    Product Manager
    Autodesk, Inc.
    10-05-2012 08:16 AM in reply to: ihayesjr
    How about the "over-write" part?  Can it be made to delete the previous night's backup?  Any plans to improve the configurability of the backup feature?
    Just so it's understood what's happening: Vault makes its full backup of X gig.  Next night, new backup next to the old one - 2X gig.  Then 3X, 4X, etc.  The backup Vault makes is then getting backed up elsewhere.  Once that's backed up, it doesn't need to be backed up again and again.  But unless we manually delete the previous files, that's what happens.
    Bill Schmid
    256 GB SSD
    Board Manager
    10-05-2012 10:11 AM in reply to: Bill.Schmid
    Here is an example script that you can use to delete the old backup.  You can modify it to fit your needs.
    @ECHO OFF
    REM PROVIDING THE BEST RESULTS FOR BACKING UP THE VAULT
    REM DELETE B AND CASCADE A BACKUP SUBDIRECTORIES
    RMDIR /Q /S "C:\Backup\Vault\B"
    REN C:\Backup\Vault\A B
    REM CREATE A NEW DIRECTORY FOR THE BACKUP
    MKDIR "C:\Backup\Vault\A\"
    REM START THE BACKUP PROCESS (THIS IS ONE LINE OF TEXT)
    "C:\Program Files\Autodesk\Data Management Server 2008\ADMS Console\Connectivity.ADMSConsole.exe" –Obackup -B"C:\Backup\Vault\A" -VUadministrator –VP<password> -S
    Irvin Hayes Jr
    Product Manager
    Autodesk, Inc.
    10-05-2012 10:49 AM in reply to: ihayesjr
    Looks a lot like a batch file.  Would this be run from outside Vault?  IT tells me Vault doesn't allow scripting.
    Bill Schmid
    256 GB SSD
    Board Manager
    10-05-2012 10:53 AM in reply to: Bill.Schmid
    Bill,
    The backup can run from command line parameters on a schedule using the Windows Task Scheduler.
    See Command Line Server Console
    You can wrap the command line in a batch file and perform what you are looking for.
    Irvin Hayes Jr
    Product Manager
    Autodesk, Inc.
    10-05-2012 11:54 AM in reply to: ihayesjr
    Looks like that ought to work.  They were setting it up and trying it.  Thank you.
    Bill Schmid
    256 GB SSD
