• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Vault
    Distinguished Mentor
    Vault Autonumbering and Copy Design
    358 Views, 4 Replies
    02-07-2012 03:30 PM
    I am testing the Autonumbering tool with IV 2012 and Vault Collaboration 2012.  I like how it works with saving files from IV, but I can't figure out how to use it during a "Copy Design" command in Vault.
    Is automatic numbering of copied files supported and where do I select the correct numbering scheme for my files?
    Please use plain text.
    Employee
    Re: Vault Autonumbering and Copy Design
    02-07-2012 07:02 PM in reply to: swalton
    Currently Auto-Numbering is not supported inside Copy Design, however, we are looking at addressing this in a future release.  In the mean, you may want to consider working around it by renaming the Copied files by selecting the desired numbering scheme from the Rename wizard.  If you are okay with using the workaround, you can also consider using a Prefix/Suffix inside Copy Design, then search for all the files having that unique Prefix/Suffix in their name and perform a batch Rename.
    Regards
    Anil Chintamaneni (Autodesk)
    Anil Chintamaneni
    User Experience Designer
    Data Management
    Active Member
    09-11-2012 02:32 AM in reply to: anil.chintamaneni
    I skip posting a new thread about this topic.
    I'll add here the same request to enforce the need of such a functionality. Both commands (numbering scheme and copy design) are very helpful functionalities inside vault but must be combined as soon as possible. It is absolutely inconvenient being forced to use the rename-command only to get auto-numbered the copied files. It's very time-consuming and leads to more unnecessary file versions.
    We're facing more and more situations where this scenario occurs - that's why it would be greatly appreciated to have this issue fixed within the next vault release 2014.
    Autodesk - please prioritize this!
    Thanks and Regards,
    DK
    09-11-2012 05:35 AM in reply to: swalton
    It would also be nice to be able to edit iproperties while in the copy design window.  That way I can fix my part descriptions without creating extra new versions.
    Distinguished Contributor
    09-11-2012 10:38 AM in reply to: swalton
    Swalton...our best work around that we have found is to have Inventor open and do a saveas. Have it grab a number and do a copy from the filename line. Cancel out of the Saveas window and then go back to Vault and paste in the number in Copy Design. I know it's not ideal, but it's the best we got right now.
