• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Vault
    Active Member
    Accepted Solution
    Vault 2012 explorer hangs when browse folder to folder fast enough
    227 Views, 11 Replies
    11-30-2012 11:13 AM
    I have a problem on one customer,
    We moved vault 2012 database to new vault 2012 server.
    New server is:
    windows server standard 2008 R2 64bit
    MS SQL server 2008 R2 64bit
    Vault standard 2012
    In MS hyper-v virtual machine.
    So the old vault was same version and restore and all installations went well, no errors or anything problem with that.
    And vault was accessible right away, I also installed all hotfixes released before update1.
    Not yet update1 cause have to update all clients when I do that and on old server there was no update1 eather.
    I have rebuilded search indexes and limited SQL memory usage to 8192mb what is recommended.
    All work well and vault opens fast from every network LAN or WAN
    But there is little annoying thing, when I browse fast to folder to folder which contain files, vault explorer hangs and I have to force close it with task manager.
    The odd thing is that when I just let explorer to show folder files before I browse to another folder it works fine, but if I dont let that second to files to show, it hangs.
    Any help?
    Please use plain text.
    Active Member
    Re: Vault 2012 explorer hangs when browse folder to folder fast enough
    11-30-2012 12:01 PM in reply to: tuomo.hiltunen
    Little update.
    I just waited long enough when vault explorer hanged(about 15min) then it popup. Error: operation( or action) time out.
    And worked fine after that again, even now I can browse folder faster than before hang and timeout????
    but again, when I browse folders a while very fast it hanged again...
    Active Member
    12-03-2012 11:44 PM in reply to: tuomo.hiltunen
    Any help? I am struggling with this problem.
    Product Support
    Olaf.Górski
    12-04-2012 01:39 AM in reply to: tuomo.hiltunen
    Hello Tuomo,
    No help directly, however, please consider following aspects which may cause performance issues. Maybe it will do help you.
    o As virtual environments could cause unexpected consequences Autodesk reserves the right to ask that any customer reported problems be reproduced on a physical machine outside the VMware environment.
    Read: Virtual environments can always cause unexpected behaviour of Vault.
    Hope it helps
    Olaf Górski
    Product Support Specialist
    GSS-Product Support EMEA
    Autodesk, Inc.
    Active Member
    12-04-2012 02:11 AM in reply to: Olaf.Górski
    Hi Olaf,
    Thanks for response.
    I have no antivirus at the moment installed on the server, and client machines are exactly the same as they was before move to the new server.
    So it cannot be antivirus problem.
    About virtual machine, vault works fine when we do anything else, opens fast, file transfer is fast, all works fine but this only thing that did not work is this fast folder to folder browse.
    Can it be some IIS web application issue?
    Board Manager
    12-04-2012 06:38 AM in reply to: tuomo.hiltunen
    Can you reproduce the problem outside of the Hyper-V environment?
    Irvin Hayes Jr
    Product Manager
    Autodesk, Inc.
    Active Member
    12-05-2012 12:13 AM in reply to: ihayesjr
    Hi Irvin,
    I can but not that easy.
    So I try to make then all the same but not in hyper-v. Same hardware and so on.
    I come back to you when I have done that.
    Active Member
    12-15-2012 05:42 PM in reply to: tuomo.hiltunen
    Ok,
    I installed all to real 2008 R2 standard server and I followed directly the advanced configuration guide and make all what it is said in there, default settings and all.
    SQL 2008r2 now without sp1 cause I found somewhere that it is not supported on 2012 vault. so now without it.
    Restored backup and all hangs starts again.... ! !"#!"#
    Ok ok, I start thinking what it can be cause all have been done exactly what guide told to do and I have googled alot of this thing and done all what I have found byt no avail..
    I disabled the require SSL on autodesk site and I tried it without SSL, and now all works fine.
    So the reason was SSL?? Can it be that brand new dell server with good Xeon and 16gb memory cannot handle 2048bit certificate?
    or it is the vault web service which cannot handle it?
    old server which worked was with 1024bit SSL certificate.
    Any guess?
    Active Member
    12-16-2012 04:05 AM in reply to: tuomo.hiltunen
    Or can it be that client cannot handle 2048bit cetificates?
    Active Member
    12-16-2012 04:35 AM in reply to: tuomo.hiltunen
    I find this link when googling long enough with ssl problems:
    http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=20350604&linkID=9261341
    But in readme it says it is for:
    • Autodesk Vault Collaboration 2012 Update 1
    • Autodesk Vault Professional 2012 Update 1
    No Vault basic? I have this problem exactly and it is on vault basic.
    Can I use this update on vault basic too? or can you make update for it?
