Vault 2012 Copy Design error; Value cannot be null; Parameter name: value
nijpels
Message 1 of 25
nijpels
Hope someone can help me with the following:
During copy design in Vault 2012 (Inventor 2012) I get an error: Value cannot be null; Parameter name: value
None of the files are copied. I've tried al kind of different ways, coping in the same folder, different prefix and/or suffix, first selecting files, folderlocatin in "To", other way around, no folderlocation in "To', and so on! I've also contacted our Autodesk supplier, but till now do they also not know what causes this.
Does anybody know what can cause this or better, has a sollution for this?
VaultServer log file attached of today 6-6-2011
Thimo
Netherlands
Thimo Nijpels
Comus Technology BV
Netherlands
http://www.dry-reeds.com
Replies (24)
Message 21 of 25
r.smith1
Hi Dan,
Thank you for your reply.  In our tests, you can set the ipj at the working folder root (example: C:\_Work) and then point your workspace to the workspace folder.  In another test, I set the IPJ file in $\ but it was mapped to C:\_Work and workspace folder was set to .\.
I hope this helps.
Ron Smith
New Product Introduction Manager
Message 22 of 25
Hi everyone,
The Value cannot be null error has been solved by changing the working folder to C:\Vault\
Not C:\
I then got an XML error, which I had seen on the cracking the vault blog.
http://crackingthevault.typepad.com/crackingthevault/2010/11/there-is-an-error-in-the-xml-document.h...
So I turned off AVG link scanner and all is absolutely fine.
Ron, I noticed the workspace was set to .\ all seems to work ok so I'm not going to change it.
Thanks everyone.
Dan
Message 23 of 25
nijpels
Hi Ron,
Thanks a lot for helping, the problem is now solved for me.
Only thing I had to change would it work was to set to enforce the working folder. Only after that the error was gone.
But it works for me now, I'm the only user.
Thimo Nijpels
Comus Technology BV
Netherlands
Message 24 of 25
nijpels
Hi all,
There is a hotfix now availeble for this isue, see message on the other thread http://forums.autodesk.com/t5/Autodesk-Vault/Vault-2012-Copy-Design-Error-Value-cannot-be-null/td-p/.... by Fay Zhang.
To go to the hotfix: http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=17235740&linkID=9261341
Thimo Nijpels
Comus Technology BV
Netherlands
Message 25 of 25
PACDrafting
Is there a copy design fix for 2011 also?
