• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Vault
    Product Support
    r.smith1
    Re: Vault 2012 Copy Design error; Value cannot be null; Parameter name: value
    06-14-2011 02:30 PM in reply to: Studioworx
    Hi Dan,
    Thank you for your reply.  In our tests, you can set the ipj at the working folder root (example: C:\_Work) and then point your workspace to the workspace folder.  In another test, I set the IPJ file in $\ but it was mapped to C:\_Work and workspace folder was set to .\.
    I hope this helps.
    Ron Smith
    Data Management Support Specialist
    Product Support
    http://wikihelp.autodesk.com/Product_Help/Autodesk_Vault
    Please use plain text.
    06-15-2011 12:09 PM in reply to: r.smith1
    Hi everyone,
    The Value cannot be null error has been solved by changing the working folder to C:\Vault\
    Not C:\
    I then got an XML error, which I had seen on the cracking the vault blog.
    http://crackingthevault.typepad.com/crackingthevault/2010/11/there-is-an-error-in-the-xml-document.h...
    So I turned off AVG link scanner and all is absolutely fine.
    Ron, I noticed the workspace was set to .\ all seems to work ok so I'm not going to change it.
    Thanks everyone.
    Dan
    nijpels
    06-17-2011 04:52 AM in reply to: r.smith1
    Hi Ron,
    Thanks a lot for helping, the problem is now solved for me.
    Only thing I had to change would it work was to set to enforce the working folder. Only after that the error was gone.
    But it works for me now, I'm the only user.
    Thimo Nijpels
    Comus Technology BV
    Netherlands
    http://www.dry-reeds.com
    nijpels
    06-29-2011 11:27 PM in reply to: nijpels
    Hi all,
    There is a hotfix now availeble for this isue, see message on the other thread http://forums.autodesk.com/t5/Autodesk-Vault/Vault-2012-Copy-Design-Error-Value-cannot-be-null/td-p/.... by Fay Zhang.
    To go to the hotfix: http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=17235740&linkID=9261341
    Thimo Nijpels
    Comus Technology BV
    Netherlands
    03-22-2012 06:17 PM in reply to: nijpels
    Is there a copy design fix for 2011 also?
