• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Vault
    Distinguished Contributor
    spascual
    Unable index outlook 2010 MSG
    291 Views, 6 Replies
    06-01-2011 08:46 AM
    Hi sirs,
    Although I have installed (and configured) the hotfix and the iFilter that solves this problem in VAULT PRO 2011 SP2, my system is unable to index the outlook messages.
    windows standard x64 2008 SP2
    sql standard 2008 sp1
    What can I do????
    regards
    Please use plain text.
    Product Support
    Andy.Spivey
    Re: Unable index outlook 2010 MSG
    06-01-2011 09:51 AM in reply to: spascual
    Can you provide any additional information or screen shots of what you are seeing? (or not seeing)
    Did you install the MSG iFilter on the client or the server?
    When mapping the UDP, did you perform an Import from Vault or Import from File?
    (if the iFilter is installed on the client machine, you should perfrom the "Import from File" command - if the iFilter was installed on the server, perform the Import from Vault command)
    Andy Spivey
    Data Management Support Specialist
    Product Support
    spascual
    06-01-2011 10:02 AM in reply to: Andy.Spivey
    I have installed MSGFILT.DLL on server.
    I have run a re-index properties task, but MSG files appears on status dialog box as iFilter not installed.
    If I try to configure the property, system says that this files has not properties to index.
    I have done "the iFilter was installed on the server, perform the Import from Vault command"
    I have installed with domain user as administrator, could be better to install de ifilter with administrator???
    regards
    Product Support
    Andy.Spivey
    06-01-2011 11:40 AM in reply to: spascual
    On the server, please verify that the MSG ifilter is not set to do content - only properties.
    When you create your mapping and choose Import from Vault, does the MSG file show properties to map from?
    Andy Spivey
    Product Support
    spascual
    06-02-2011 12:14 AM in reply to: Andy.Spivey
    On the server, please verify that the MSG ifilter is not set to do content - only properties. YES
    When you create your mapping and choose Import from Vault, does the MSG file show properties to map from? NO
    System says that is unable to extraxt from this kind of files.
    regards
    It seems like the iFilter was not present, is not registered. But in the dialog box of indexing says that is installed.
    regards
    spascual
    06-02-2011 01:51 AM in reply to: Andy.Spivey
    Hi Andy
    I can do it uninstalling FILE SERVER ROL on server, and configure the property in Vault from a client and from a local file extraction
    thankssssss
    Product Support
    Andy.Spivey
    06-02-2011 08:53 AM in reply to: spascual
    Just to clarify, you have been successful in pulling in the properties by installing the MSG filter on the client and performing an "Import from File" command?
    Andy Spivey
    Product Support
