• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Vault
    Show Vault file path
    260 Views, 7 Replies
    10-21-2011 06:29 AM
     When we do a search with "search subfolders" checked, is there a way to view the Vault file path for a specific file without going to the folder?  Is there any option for this in custom view or properties?
    I really need to know what folder the searched files are in.
    Please use plain text.
    Product Support
    Re: Show Vault file path
    10-21-2011 07:20 AM in reply to: patricksalvador
    You can customise the view to show the "Path" property
    ______________________________________________________________
    If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
    Richard Rankin
    Data Management Support Specialist
    Autodesk Support
    10-21-2011 07:34 AM in reply to: Richard.Rankin
    I cannot find "Path" under the customize view options.
    I'm using Vault Collaboration 2011.
    Product Support
    10-21-2011 07:51 AM in reply to: patricksalvador
    The "Path" field is a new feature in Vault 2012. You would need to upgrade to take advantage of that.
    Richard Rankin
    Autodesk Support
    10-21-2011 07:55 AM in reply to: Richard.Rankin
    Can I create a "Path" property?  User Defined Property?
    ScottMoyse
    10-21-2011 05:49 PM in reply to: patricksalvador
    yes but you would have to fill it in on every file manually or via code.
    Cheers
    Scott Moyse
    Please use Mark Solutions!.Accept as Solution &Give Kudos!Kudos to further enhance the value of these forums. Cheers!
    New Member
    03-06-2013 07:23 AM in reply to: Richard.Rankin
    You guys should be wearing a mask, this is one of the most basic features I can think of - not putting it in and then telling people to upgrade really has a significant impact on your reputation - disgusted.
    Employee
    minkd
    03-06-2013 10:13 AM in reply to: Russ41
    In earlier versions of vault, a file could have many paths because it could be "shared" to multiple folders. All shares were considered equal so there was no "primary" path. Once we finished phasing out shares (we replaced them with links), we were able to show a property in the grid for the path.
    -Dave
    Dave Mink
    Data Management
