SQL R2 Express Limit.
BL4849
BL4849
Can someone confirm that the "10GB Limit" in SQL R2 Express is the size of the SQL Databases and NOT the Total, including the Filestore.
In either case what happens when this limit is reached?
Thanks in advance
paul.gunn
You are correct - this is a database limit, filestore size is not relevant here.
When the limit is reached, you will start seeing SQL errors usually reported as 109 errors in the applications. The details in the log indicate that the database can no longer be grown.
Hope this helps,
Paul
johan.degreef
Can you recover from it?
Inventor 2025, Vault Professional 2025, Autocad Plant 3D 2025
GunnarNilsson
Yes, just run setup from SQL Standard media and choose Maintenance, Edition Upgrade
https://learn.microsoft.com/en-us/sql/database-engine/install-windows/upgrade-to-a-different-edition...
