• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Vault
    Distinguished Contributor
    Accepted Solution
    Restoring replicated backup to test environment
    184 Views, 6 Replies
    02-20-2013 07:24 AM
    I have seen a few posts about retoring backups, but nothing that I have seen covers this exactly.
    We have a fully replicated multi site environemnt. I want to be able to restore this environemnt on a different set of machines.
    The problem I cant seem to get around is how to enable the new sites without completely replicating the databases and servers. Simply adding new workgroups causes the datasbases to copy again from the publisher. All the ownership settings and anything related to the previous workgroup is removed. On top of that, if there are problems in our production environment, a complete replication could potentially hide an issue at a subscribing site.
    So for example, I have production servers 1(publisher), 2,3...I want to create an EXACT duplicate on servers A(publisher),B,C
    How is this possible?
    Jeremy
    Please use plain text.
    Board Manager
    Re: Restoring replicated backup to test environment
    02-20-2013 08:25 AM in reply to: jparks_79
    In order for you to restore the subscribers you will need to use a 3rd party utility to backup the subscribers then restore then subscribers in your test environment.
    Irvin Hayes Jr
    Product Manager
    Autodesk, Inc.
    02-20-2013 08:49 AM in reply to: ihayesjr
    Hi Irvin,
    With the third party utility, is it possible to restore those subscribers on different servers with different names and IP address?
    Jeremy
    Board Manager
    02-20-2013 09:54 AM in reply to: jparks_79
    Jeremy,
    No, you still have to restore to the same computer names if you are not planning to completely setup replication again in your test environment.
    Irvin Hayes Jr
    Product Manager
    Autodesk, Inc.
    02-20-2013 11:19 AM in reply to: ihayesjr
    Irvin,
    Any recomendations for when all machines reside on the same domain?
    -Jeremy
    Board Manager
    02-20-2013 12:12 PM in reply to: jparks_79
    You will have to setup an isolated network from your production network.  That is the only way to make this work.
    Irvin Hayes Jr
    Product Manager
    Autodesk, Inc.
    02-20-2013 12:15 PM in reply to: ihayesjr
    :smileysad:
    Ok. Thanks for the guidence!
