Autodesk Vault
Topic Options
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Printer Friendly Page
Publish
Options
- Highlight
- Email to a Friend
- Report Inappropriate Content
144 Views, 2 Replies
06-08-2009 07:32 AM
Hello ,
I am programming in C # and add the design does not generate the Thumbnail DWG and DWF neither, so I have to enter the product stream and click the Update button.
have any command via API to make the publication?
Code add File:
DocumentoAdd = docSvc.AddFile(folder.Id, filePath, "Arquivo Adicionado",
System.IO.File.GetLastWriteTime(filePath), null, null, null, null, null , DocReference.FileClassification.None, false, bytes);
Att.,
Darcy
Code add File:
Att.,
Darcy
*Doug Redmond \(Autodesk\)
Re: Publish
Options
- Highlight
- Email to a Friend
06-09-2009 04:45 AM in reply to:
trafo2009
Let me repeat your question to make sure I understand.
You are adding in a file through the API and it's not creating the DWF and
DWG thumbnail file. These files get created when you add a file through the
CAD plug-in.
ADMS does not generate any files. So if you want a DWF to go with your
design file, you need to generate the DWF yourself and add it to
Vault/Productstream.
In Vault Collaboration and Vault Manufacturing 2010, there is an additional
option. If you have the job serviece set up, you can add a DWF generate job
instead of creating the DWF yourself.
Doug Redmond
Software Engineer, Autodesk Inc.
CAD plug-in.
Doug Redmond
Re: Publish
Options
- Highlight
- Email to a Friend
06-09-2009 07:11 AM in reply to:
trafo2009
so so,
Doug: You are adding in a file through the API and it's not creating the DWF and DWG thumbnail file.
Doug: These files get created when you add a file through the CAD plug-in.
Darcy: how create this files? because if this files not create , the web user has installed Autocad.
att.,
att.,
