• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Vault
    New Member
    Producstream and virtual components
    161 Views, 1 Replies
    03-30-2007 07:12 AM
    Inventor 11 allows to create virtual components in a assembly. For example here is the structure of my product:
    Drawing.idw
    |_Main-ass.iam
    |_part01.ipt
    |_part02.ipt
    |_part03.ipt
    |_virtual-component
    (BOM Structure for each element is defined on "Normal")
    In Productstream 5, when I assign items to my product < Product 1 >, I obtain the following BOM:
    item1 Main-ass
    item2 |_part01
    item3 |_part02
    item4 |_part03
    item5 |_virtual-component
    When I show files associated with the article " virtual component ", I see the files " drawing.idw " and "main-ass.iam":
    item5 virtual component
    file1 |_main-ass.iam
    file2 |_drawing.dwg
    Let us imagine that this virtual component is used by 50 products, all were defined by an assembly and a drawing. The list of files associated with the item contains 100 files:
    item5 virtual-component
    file1 |_main-ass-01.iam
    file2 |_drawing01.dwg
    file3 |_main-ass-02.iam
    file4 |_drawing02.iam
    filex |_...
    filey |_...
    file99 |_main-ass-100.iam
    file100 |_drawing100.iam
    Let us imagine that this virtual component is defined by a note (note.pdf) associated as attached file in the item" virtual component ".
    filex |_...
    filey |_...
    file101 |_note.pdf
    It becomes difficult for a Reviewer or a productstream explorer user to locate note.pdf inside all the files iam and idw.
    So my question is :
    Is there a means to create an item associated with a virtual component defined in Inventor, without seeing in the "attached files" section of a virtual component item, all the assemblies and drawings used by a virtual component?
    Please use plain text.
    *Bill Schwerin
    Re: Producstream and virtual components
    04-03-2007 02:02 PM in reply to: sebastien.lourdel
    We don't currently have a filter for what is displayed in the attached files
    list.
    Do you want a filter that is targeted at virtual components, or would a more
    general approach work? Something Productstream specific (Hide secondary
    links, Hide design document links) would be much easier to implement and
    maintain than something Inventor specific (Hide links related to Virtual
    components).
    Bill Schwerin
    Software Engineer
    wrote in message news:5536349@discussion.autodesk.com...
    Drawing.idw
    |_Main-ass.iam
    |_part01.ipt
    |_part02.ipt
    |_part03.ipt
    |_virtual-component
    item1 Main-ass
    item2 |_part01
    item3 |_part02
    item4 |_part03
    file2 |_drawing.dwg
    filex |_...
    filey |_...
    filex |_...
    filey |_...
    file101 |_note.pdf
    So my question is :
    component?
