• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Vault
    Member
    Problems after upgrading from 2012 to 2013
    187 Views, 4 Replies
    09-25-2012 01:20 PM
    Our office just upgraded from autodesk 2012 to 2013, in doing this we upgraded out vault server.  To upgrade the server, we backed up the existing database, then unistalled vault 2012, we then installed vault 2013.  Then we migrated the database.
    Now when we connect to vault 2013 from inventor 2013, we do not get any content center libraries, but if we connect to vault 2013 from inventor 2012 we can see all the content center libraries.  How do I make there libraries available to the inventor 2013?  We have no need to maintain there availablity to inventor 2012.
    Please use plain text.
    Employee
    olearya
    Re: Problems after upgrading from 2012 to 2013
    09-25-2012 04:15 PM in reply to: Bsmithiii
    Hi there,
    Did you actually install the Inventor 2013 Content Center in ADMS?  You need these installed to access the content from 2013.  Any custom libraries can be migrated from 2012 to 2013 but standard libraries need to be installed from the new media.
    Allan
    Product Manager
    Be sure to check out the Vault Help Wiki!
    Member
    09-26-2012 05:40 AM in reply to: Bsmithiii
    Ok talking to my IT guy, we backed up the old database, and then he retored it, over righting the new database.  Can i export the custom Libraries from the current database and re import them such that they migrate to 2013?  and can i reinstall the default libraries without overrighting the current database?
    Employee
    olearya
    09-26-2012 05:51 AM in reply to: Bsmithiii
    Sure, to migrate custom libraries you simply need to copy these to 2013 and install the new 2013 libraries from disk  You can then remove any old libraries you are not using.  Full details can be found here on the Wiki:
    http://wikihelp.autodesk.com/Vault/enu/Help/Help/0097-Administ97/0098-Autodesk98/0109-Manage_C109
    Allan
    Product Manager
    Member
    09-26-2012 10:01 AM in reply to: olearya
    thank you,
    I am up and running now.
