• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Vault
    Distinguished Contributor
    Re: Problem adding library components to vault 2013
    08-30-2012 01:11 AM in reply to: rikard
    Also have the same problem with customers upgraded from 2012 to 2013, applies to both Content Center Parts and Library Parts.
    Any news on this?
    Please use plain text.
    Valued Contributor
    ndra
    09-07-2012 05:06 AM in reply to: hans.martin.haga
    Same problem here, any news?
    Smilingers workaround is not applicable in our case.
    *Expert Elite*
    ScottMoyse
    10-05-2012 09:27 PM in reply to: hans.martin.haga
    What a PITA! this has hampered my AU class prep. Any news? Autodesk?
    Cheers
    Scott Moyse
    Please use Mark Solutions!.Accept as Solution &Give Kudos!Kudos to further enhance the value of these forums. Cheers!
    Employee
    mollons
    10-08-2012 06:02 AM in reply to: hans.martin.haga
    We are currently working to address this issue.
    More details to follow when we have an estimate on when the fix will be released.
    Scott Mollon
    Quality Assurance
    Autodesk, Inc.
    Be sure to check out the Vault Help Wiki!
    10-23-2012 12:31 AM in reply to: hans.martin.haga
    Any news on this?
    dominik.gleinser
    10-29-2012 08:22 AM in reply to: hans.martin.haga
    Any news?
    Employee
    mollons
    10-29-2012 08:35 AM in reply to: hans.martin.haga
    We are still working to fix and test the issue.
    Scott Mollon
    Quality Assurance
    Autodesk, Inc.
    dominik.gleinser
    10-30-2012 12:25 AM in reply to: mollons
    Okey. Thank you...
    Employee
    mollons
    12-13-2012 08:44 AM in reply to: dominik.gleinser
    This is has been fixed in Vault 2013 SP1 available now.
    http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=21017345&linkID=9261341
    Scott Mollon
    Quality Assurance
    Autodesk, Inc.
    01-31-2013 03:20 AM in reply to: mollons
    Please note that we have been having this problem and it "HAS NOT BEEN SOLVED BY THE VAULT SP1"
    Please let me know what I should do.
