Vault Forum
Welcome to Autodesk’s Vault Forums. Share your knowledge, ask questions, and explore popular Vault topics.
Object reference not set to an instance of an object - Job Server Queue Error
14 REPLIES 14
Message 1 of 15
jweiss1313
5390 Views, 14 Replies
We are new Autodesk Vault Professional 2011 users. (Only two weeks).  I have an Inventor 2011 assembly file that throws an error in the Job Server Queue.  The assembly in in the Work In Progress state and its components are a mixed of Released, WIP and For Review.  I can check the file out and open it in Inventor and select the Export command and create a dwf file.  I also get an error when trying to create the dwf file locally using the Vault client.
Does anyone have an idea what this error means and how do I fix this issue.
John C Weiss Jr.
CAD Manager
Follett LLC.
14 REPLIES 14
Message 2 of 15
Andy.Spivey
in reply to: jweiss1313
John,
Have you noticed this with just a single file?
If so, how large is the file?
If the file is larger than 30 MB, what OS is hosting the Vault server?
Andy Spivey
SQA Engineer
Message 3 of 15
jweiss1313
in reply to: Andy.Spivey
Hi Andy,
Sorry it took me so long to reply, but I've been having issues connecting to the Autodesk discussion groups the past week. The issue seems to be a single file that is 600KB in size.  The Vault server is running on Microsoft Server 2008 SP2 x32.
John C Weiss Jr.
CAD Manager
Follett LLC.
Message 4 of 15
Andy.Spivey
John,
If it is a single file, can I have you upload it for review?  I can create a 1:1 ticket as you are on subscription so you do not need to post the file on the discussion group (unless you wish to do that).
Andy Spivey
SQA Engineer
Message 5 of 15
Andy.Spivey
To close the loop on this thread - the file generating the error had been renamed and there was an outstanding DWF file still in the vault.  Once the old DWF was deleted, the file showing the error in the job processor was able to be processed without error.
Nice catch John!
Andy Spivey
SQA Engineer
Message 6 of 15
scottmoyse
andy cheers for making the effort to come back and post the results, a lot of people dont
Scott Moyse
Design & Manufacturing Technical Services Manager at Cadpro New Zealand
Co-founder of the Grumpy Sloth full aluminium billet mechanical keyboard project
Message 7 of 15
mbodnar
Hi Andy
I have a replicated environment (Vault Collaboration 2012 SP1, Windows 2003, SQL 2008) where on one site  2 Vault clients show this error when submitting jobs to Job processor. Previosuly the error did not exist and Job processor was working OK
At the other sites, this error doesnt occur.
Also when attempting to update DWF manually thru Vault Explorer, the system show error "An error was returned while attempting to create the visualization file. The visualization file was not created"
Account logged is is Admin and has full access to modify files
Do you have any suggestions on how to resolve the error. I re-installed the vault client but error still comes up.
This happens on all of the files from the two clients from one site ONLY.
I have raised a support ticket with Autodesk but have had no solution as yet
thanks in advance
Max Bodnar
Message 8 of 15
mbodnar
Sorry forgot to mention using Inventor 2011 SP2 on Windows XP64
I just tried a third client at the same site where the other 2 are having the error, and the third client works OK
The only thing that is different between the 2 clients that dont work and the client that does work, is the 2 clients have some additional Vault custom tools installed from the "Cracking the vault website" (lifecycle status and copy hyperlinks)
regards
Max Bodnar
Message 9 of 15
Andy.Spivey
in reply to: mbodnar
Max,
On the site with the issue, can you locally create a DWF file (not through the job processor, but through the Vault Client - Local update command?)
Does it complete successfully?
Andy Spivey
SQA Engineer
Message 10 of 15
mbodnar
Hi Andy
Thanks for the reply. Yes I can create DWF's manually and thru job processor on the other sites.
Even on the site where it doesnt work under one windows user profile (user A on machine A), logging into widows with user B on machine A appears to work. I logged into the machine that has the same problem (machine B) but neither account A or B works.
I also deleted and recreated profile for user A on machine A, but I still get the error
This is the error that shows up in the event viewer
Error 17-Jan-12 1:02:36 PM
Job 220000000356 Autodesk.Vault.DWF.Create.ipt : Object reference not set to an instance of an object.
Exception: System.NullReferenceException: Object reference not set to an instance of an object.
   at DWFGenerator.InventorSelector.IsInventorLT()
   at DWFGenerator.InventorDWFEngine.IsSupportedFile(String fileFullName)
   at DWFGenerator.DWFCreateCenter.CreateDWF(String srcPath, String destDWFPath, ArrayList layoutList)
   at DWFGenerator.DWFCreateCenter.CreateDWFFile(String srcPath, Int64 inventorVersion, SourceDocumentTypeEnum docType)
   at Connectivity.Request.ExtensionHandler.Inventor.Internal.UpdateViewExtensionHandler.Connectivity.Request.Document.Currency.ExtensionHandler.IUpdateViewExtensionHandler.CreateDwfFile(RequestContext rContext, FileOperationRecord file, String workingFolder)
   at Connectivity.Request.Document.Request.ExtensionHandler.UpdateView.CreateDwfFile.Execute(RequestContext rContext)
   at Connectivity.Request.Common.CommonRequest`1.ExecuteRequest(RequestContext rContext)
   at Connectivity.Request.Runtime.RequestExecutor.Execute(IRequest req, RequestInstance reqInstance)
   at Connectivity.Request.Runtime.RequestExecutor.Execute(IRequest req)
   at Connectivity.Explorer.Document.ViewModel.UpdateViewContextExtensions.CreateDwfFile(UpdateViewContext context, FileOperationRecord file, String workingFolder, String publishOptionsXml)
   at Connectivity.Explorer.Document.ViewModel.UpdateView.CreateDwfImpl()
   at Connectivity.Explorer.Document.ViewModel.UpdateView.CreateDwf(Boolean& isCancelled)
   at Connectivity.Explorer.JobHandlerDwfPublish.InventorDwfJobHandler.Execute(IJobProcessorServices context, IJob job)
Regards
Max Bodnar
Message 11 of 15
mbodnar
I dont think the Vault custom tools have any effect, I un-installed them and Job Processor error continues to exist
Regards
Max Bodnar
Message 12 of 15
Andy.Spivey
You noted above that there was a ticket currently logged with support, can you PM me the # for review to try to help?
Andy Spivey
SQA Engineer
Message 13 of 15
mbodnar
Hi Andy
It would be great if you could assist, case no is 06862582
regards
Max Bodnar
Message 14 of 15
This might not apply to this specific case, but I was having similar errors. I noticed that our server was running two copies of job processor (under different user accounts), so I killed one and the problems went away. I had a tried a number of other things, but after reducing the number of instances to one, everything worked correctly.
Message 15 of 15
mbodnar
Hi
In this instance, we found that the JP and the manual Update from Vault Explorer would not work until we removed Vault SP1. Once SP1 was removed, both the JP and the manual update work
Max Bodnar
