Autodesk Vault
Topic Options
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Printer Friendly Page
No(file is not checked out of Vault)
Options
- Highlight
- Email to a Friend
126 Views, 3 Replies
09-07-2006 12:48 PM
When I try to save an assembly, I am greeted with a Save dialog. In it, several of the files have "No(file is not checked out of Vault)".
Is Vault wanting to save this file? if not, then why is it even showing me this.
Does the file need to be updated in some why?
If I change this to "Yes(file is not checked out of Vault)", then I get the Edited-out-of-turn. Which, to me, I do not like to see.
Can someone please explain.
Vault5-sp1
Vault5-sp1
*Adam Luttenbacher \(Autodesk\)
Re: No(file is not checked out of Vault)
Options
- Highlight
- Email to a Friend
09-08-2006 06:31 AM in reply to:
karthur1
Thank you for your post Kirk,
You are greeted with that dialog because Inventor is populating it, not
Vault. The Vault add-in is simply adding your file status information as a
warning.
To resolve this problem, navigate to Tools>Application Options. In the
"Save" tab, you will see an option "Do not list referenced files that
default to "No" in the Save dialog." Checking this box should eliminate
these extra files from you save dialog.
Adam Luttenbacher
wrote in message news:5321397@discussion.autodesk.com...
this.
Vault5-sp1
warning.
Adam Luttenbacher
this.
Vault5-sp1
Options
- Highlight
- Email to a Friend
09-08-2006 07:05 AM in reply to:
karthur1
Adam,
"...Vault add-in is siimply adding your file status information as a warning...."
A warning about what? I am trying to figure out why this comes up for some files and not others. Is vault thinking that the file needs saving or that it has changed? What flags vault to prompt this?
I would prefer not to use the "Do not list referenced files that default to "No" in the Save dialog". If I use this, it seems that I am just hiding a problem. I had rather fix it, rather than cover it up all the time.
Kirk
Kirk
Options
- Highlight
- Email to a Friend
10-03-2011 12:23 AM in reply to:
karthur1
Hi
If one or more of the parts in a assembly is not migrated the "is not checked out" appear. I would wish that Autodesk could give me the option to "check out and save" those files from the "save" dialog box.
Asle Martin Svastuen
Autodesk Product Design Suite Ulitmate 2012 Sp1 / Vault Collaboration 2012 Sp1
HP EliteBook 8560w
Intel(R)Core(TM) i7 CPU Q 720 @ 2,0GHz 2,0GHz
16GB RAM
Windows 7 X64 SP1
HP EliteBook 8560w
16GB RAM
Windows 7 X64 SP1
