• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Vault
    New Vault Library
    103 Views, 7 Replies
    06-13-2012 05:10 AM
    What is the process for adding a new Library to Vault ?  The library must be located on the Server.  I have created one, but now the copy design feature does not work.  I get a HRESULT 0x8000040005 error .
    Please use plain text.
    Employee
    Re: New Vault Library
    06-13-2012 06:57 AM in reply to: jerr72
    Are you trying to populate the new library with copy design?  Does copy design fail all the time or in the context of certain files or libraries?  Adding a new library to the vault depends on the library.  There is a process for importing an already existing one and there is a process for creating an empty one.  Here is a link to the wiki that might help you out:
    http://wikihelp.autodesk.com/Vault/enu/Help/Help/0097-Administ97/0098-Autodesk98/0109-Manage_C109
    -Jim
    06-13-2012 07:06 AM in reply to: jerr72
    I am creating a new library.  It is after the library was created that copy disign does not work.  I am not using copy design to populate the library.  I use copy design to copy an existing project to reuse elswhere.
    Employee
    06-13-2012 07:12 AM in reply to: jerr72
    Interesting...  Can you tell me what version of Vault you are using so I can attempt to reproduce the problem here?  Also, what type of OS are you using?
    -Jim
    06-13-2012 07:25 AM in reply to: jerr72
    It is version 2010 standard.
    Employee
    06-13-2012 08:33 AM in reply to: jerr72
    I am not quite sure on what version 2010 standard means.  Is that Vault 2010 (Basic), Vault 2010 Workgroup, Vault 2010 Collaboration, or Vault 2010 Professional?  Also, what OS are you using?  I am assuming you mean Vault 2010 (Basic) and are probably running Windows 7.  But, I want to double check.
    Jim
    06-14-2012 05:12 AM in reply to: JamesMcMullen
    It is Vault Basic - Windows 7 64.
    Employee
    06-14-2012 08:03 AM in reply to: jerr72
    Thanks...  I will attempt to set aside time today to create the environment and attempt to reproduce the issue.
    -Jim
