• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Vault
    Product Support
    r.smith1
    Moving iParts in Vault
    153 Views, 1 Replies
    05-08-2012 09:55 AM
    A support request came in and wanted to share the outcome with the forums.
    Moving iParts in Vault is difficult and presents you with errors.  We really need to move some iparts and their child parts/folders. Vault just says that it isn't allowed.
    Response to follow in next post.
    Ron Smith
    Data Management Support Specialist
    Product Support
    http://wikihelp.autodesk.com/Product_Help/Autodesk_Vault
    Please use plain text.
    Product Support
    r.smith1
    Re: Moving iParts in Vault
    05-08-2012 09:58 AM in reply to: r.smith1
    Use the Update File Reference command in Vault client before attempting your move of your files.
    Move the iPart factory, be sure the iPart member folder moves with it.
    If you try to move the folder or the member files, you will not be able to move the iPart.
    If you have saved non iPart children in the iPart member folder, you may also generate errors.  Please move these non iPart member files from the iPart member folder and continue with move.
    Ron Smith
    Product Support
